oil pressure line
Old Apr 13, 2014 | 06:02 PM
Vmason's Avatar
Default oil pressure line
Ended up changing my power steering pump today and when it was all said and done I found a small black hose under my truck. Got in started it up no oil pressure so im guessing that that small black hose os to blame. I did not take it out on purpose so I have no idea where it goes my best guess is by the power steering can anyone help me out? Mabye even with pictures?
Attached Thumbnails oil pressure line-1397430003520.jpg   oil pressure line-1397430037867.jpg
Old Apr 13, 2014 | 10:28 PM
4x4manonbroke's Avatar
almost looks like a diff vent hose ... or a TV cable
Old Apr 13, 2014 | 10:31 PM
Vmason's Avatar
almost a 100% sure that it is from the oil pressure gauge because now it will not read it
If any one has a second gen cummins wanna look around there power steering pump for this?
Old Apr 14, 2014 | 06:18 AM
JBearSVT's Avatar
Coincidence. The oil pressure gauge is all electric. What size is the hose? what does it smell like? I agree that it looks like a vent or vacuum line for the trans or transfer case, unless it's bigger in which case I'd say it's the bleeder hose from the fuel filter canister... although I don't remember that being dimpled for a clamp on both ends. Regardless, unless the '97 was completely different from the '98, it has nothing to do with your oil pressure gauge. What's more likely is that you broke/unplugged the oil pressure sensor, because it's right behind the PS pump.
Old Apr 14, 2014 | 07:42 AM
mysterync's Avatar
That's the vacuum tube that runs from the pump elbow to the cowl/firewall. Maybe your oil pressure sending unit just randomly took a cap or for could have snapped the connector off.
Sent from my SCH-I605 using Tapatalk 2
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
|WYG|SS
May 7, 2015 04:57 AM
jhprice
Mar 29, 2015 09:36 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
