08' cummins won't start
Old Apr 13, 2014 | 01:05 PM
Clifford08's Avatar
Default 08' cummins won't start
I have an 08' dodge 3500 and back in Jan. my serphantine belt split in two and one half wrapped around the crank pully. I did not realize it at first. I replaced the belt but the truck would not start, being below zero at the time I just figured it was because of the temp outside. Prior to this I drove the truck daily without having to worry about using #1 fuel or additives and will use an additive before the over priced and poor #1 fuel. So being cold out I thought I had my first gell up so I replaced the fuel filter and the fuel was fine in the filter anyways. I then though the lines were gelled so to test I sprayed either in the air cleaner and it started right up and stayed running. After a half hour or so I shut it off and tried to start it again and it wouldn't without either. I then parked it till recently and since the weather is nice now and it still won't start without help. I did find that when the belt split it wore into the crank positioning sensor so I replaced it and that still did not help.
Anyone have any ideas on what I should check or do? Would would the throttle control sensor do this? Help thanks!
Anyone have this sort of problem before, help will be appreciated? Thanks
Last edited by Clifford08; Apr 13, 2014 at 01:05 PM. Reason: Automerged Doublepost
Rusher48
Jul 2, 2020 08:39 AM
mcclusk
Feb 21, 2015 09:50 PM
Rusher48
Feb 20, 2015 05:19 PM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
