chip for a 1994 powerstroke
Old Apr 12, 2014 | 06:40 PM
fordpowerstroke1995's Avatar
Default chip for a 1994 powerstroke
hey guys I read somewhere a while back that you couldn't add a chip or programmer to a 1994 powerstroke. is that true or can you add a chip. info will be greatly appreciated. thanks
Old Apr 12, 2014 | 08:43 PM
MAFoElffen's Avatar
94.5 DIT right? Do you know the PCM hex code? The sticker/tag will be on the drivers side of the PCm's connector.
Old Apr 12, 2014 | 09:44 PM
joebob3093's Avatar
Moderator
If it is a powerstoke you can chip it. If its the IDI you cannot
Old Apr 14, 2014 | 07:47 AM
thanks guys. and yes it is the 1994.5 with the powerstroke in it. and when I go to the diesel performance websites to order a chip it only gives me an option to order a chip from 95-03 trucks so if I order one for a 95 will it work in the 94
Old Apr 14, 2014 | 12:03 PM
94turbostroker's Avatar
The 94.5 powerstrokes are the same as a 95. I found when you're ordering parts for the engine to call it a 95. There's no difference in the engine, jus the name plate on the side is the only difference.
Old Apr 14, 2014 | 05:29 PM
joebob3093's Avatar
Moderator
call up someone like gearhead and get a chip from them. dont waste your money on anything like edge or superchips
Old Apr 15, 2014 | 12:04 AM
lukesdiesel's Avatar
We carry Gearheads
DieselDawg
Old Apr 15, 2014 | 11:04 AM
MAFoElffen's Avatar
Originally Posted by lukesdiesel
We carry Gearheads
DieselDawg
I'm confused by that. I'm assuming he should call you then right? Because if he goes to your website, he will be lost. Those mentioned specific items are not in your OBS Section. Your website is short on items for OBS PSD's. Lot's of broken links, missing pictures and blank item categories. I don't mean to sound critical, but that's what I do for a living now. That's what I fix. I'm a programmer. If you need some help on getting your website polished... Please PM me.
One thing that is filled out there is the section he will be visiting-- which has 2 Edge tuners and a TS 6-position. (In the OBS Electronics Page,) The Edge tuners have Edge specific canned tunes. The one there that MAtt might openly do (the TS) and it says it has TS canned tunes. I have to say that that would be an amazing price on that 6-position TS Chip set... as that is almost just as low as the wholesale "blank" TS chipsets available to tuners to burn their own tunes onto. So usually that low a price is the Chip + the set of custom tunes price... coming to beween $425 to $450. Your posted price there would be a steal and would recommend that if it is as it is as described.
Gearhead (Matt) does a lot of tunes, but he or his tunes are not mentioned in that section of your website at all... Is that just a website oversight? And what volume discount do you have with Gearhead products, that will entice people to buy through you?
You have your door opened... I'm just trying to help you out here. Finish your sale. Tell him why Gearhead's tunes and why through you.
fordguy7.3
Apr 21, 2016 12:20 AM
Lsugod85
Jun 20, 2015 05:14 PM
Dieselhead1052
Nov 26, 2014 05:43 PM
Dieselhead1052
Nov 26, 2014 05:42 PM
corey352
10
Nov 20, 2014 08:04 AM
