fass fuel system question
Old Apr 6, 2014 | 08:03 PM
Kbnecessary's Avatar
Default fass fuel system question
I just picked up a FASS ADJ 1004 witch is the adjustable kind I was wondering what is the recommended fuel pressure for a 12 valve with moderate upgrades and also should I go with 1/2 or 3/8ths fuel line I didn't buy this thing new so I don't have the install kit it comes with originaly
Old Apr 6, 2014 | 10:11 PM
coors_man_2005's Avatar
I would go with the 1/2" line just for the volume. From what I have read the psi should be around 20 psi at idle. Also you may want to switch to a torq technology fuel releif valve. If you havnt already. It helped my truck a lot idle a lot smoother and runs better
Old Apr 6, 2014 | 10:45 PM
4x4manonbroke's Avatar
yeah an adjustable return line kit is a must ....
Old Apr 7, 2014 | 08:59 PM
yes I am getin a torqtec ofv but the one I was lookin at isn't adjustable but it espiacialy for fass and air dog systems, so 20 psi is all I need at idle wont it go down as rpm rises I figured you needed more psi than that but I have never messed with a fass that replaces the lift pump all the ones for big truck you just add them to the system no adjusting necessary
Old Apr 8, 2014 | 05:35 PM
akcoalroller's Avatar
i believe tork tec recommends 22psi at idle.
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Jet A Fuel
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
