NEED HELP ASAP
Old Apr 3, 2014 | 05:04 PM
Jordan Waggoner's Avatar
Default NEED HELP ASAP
I work an hour away from home. I am driving my 01 duramax, and the brake pedal started getting really soft. Check under the hood, and the reservoir is very low and leaking fast from one of the lines. To make matters worse its sleet/rain/snowing out, so the whole truck is wet and it is impossible to figure out where it is actually leaking from. Now I have to drive an hour home at 9:30 PM in what will be a blizzard.
The front side of the reservoir is low, does this go to the front or back wheels (i know on my 2000 impala front side goes to the back wheels).
IF i buy a plug, unhook the front brake line coming out of the front side of the reservoir, with this give me brake pressure back at the bedal and stop my leak, or will the ABS valve just direct the fluid back to the leaking line and cause it to leak still.
Basically I am asking if I should plug the line for my drive home until I can fix it, or if that wont make any difference should I just risk the drive home without messing with it.
Thanks in advance for any and all input!
Old Apr 4, 2014 | 03:12 PM
2004LB7's Avatar
Bump
hope you go this sorted out and got home safe.
I think you can block off the line but and run with only three brakes working but i think you will loose the ABS function. are you sure it was the line and not a crack in the reservoir?
Old Apr 28, 2014 | 11:34 PM
lpsl12's Avatar
I would be of the mind to check the line behind the fuel tank. An excellent place for salt and mud to gather and rust your line out ... Happened on my 2001. Gotta drop the tank to replace the line. :-)
Old May 3, 2014 | 12:14 PM
bayko's Avatar
Or just not drive in a blizzard with iffy (if any) brakes.
Old May 4, 2014 | 04:22 PM
4x4manonbroke's Avatar
might be able to make a patch line between the leak and the master cylinder
GT_Eleanor
Aug 25, 2015 09:35 AM
willis964x4
9
Aug 22, 2015 12:21 PM
jeremiah1
Jun 21, 2015 06:45 AM
canigeta727
Mar 18, 2015 05:00 PM
yfzrunner
Feb 7, 2015 10:52 PM
