7.3 Econoline Van No Power
Old Apr 24, 2008 | 07:56 PM
rpierc12's Avatar
Default 7.3 Econoline Van No Power
Ok, it's not mine but, I'm trying to help a guy out.
It starts when the block is warmed for a couple hours. Still no power.
Oil changed, new cps. All glowplugs work but 1. Fuel filter ok. And a reman ecu.
134k miles. When it does start it barely moves itself around on level ground. Even with no load it takes awhile to build rpms and spool the turbo. You guys have any ideas??
Old Apr 24, 2008 | 07:58 PM
wildbill's Avatar
Does it smoke, blue, black, gray, or white? Exhaust have an odor, like burning oil, unburnt fuel?
Old Apr 25, 2008 | 07:42 PM
rpierc12's Avatar
it doesn't smoke at all. It does smell like alittle raw fuel.
Old Apr 25, 2008 | 08:12 PM
JON's Avatar
JON
Member
Default raw fuel
if it smells like raw fuel out the exhaust it is most likely going to be a loose injector or injector orings on one or more cyls. Really need to run a contribution test to see what cyl it may be.
Old May 7, 2008 | 10:03 AM
rpierc12's Avatar
Default new question
well, i found that only the passenger side of the engine is running. I tested this with a laser thermometer and only one side of the engine has hot exhaust gases.Oh, there is also no diesel rattle on the dead side.I'm thinking it could be the injector computer as I have already replaced the ecm. What do you think.
Old May 10, 2008 | 12:07 AM
any new developments on this?
Old May 18, 2008 | 09:59 PM
Texas_Outlaw's Avatar
Pull the valve cover on the side that is dead and check to make sure the harness is pluged in at the valve cover. There is a connector inside and outside and the inside connector is known for wiggling loose or cocking to one side disabling the bank.
Old May 19, 2008 | 01:01 AM
Please update if you have a chance.
Old May 20, 2008 | 04:46 PM
DB Admin's Avatar
Banned
Did you Try This ?
Locoster
Jun 22, 2015 10:54 AM
Texasthb
Mar 4, 2015 08:20 AM
