Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
trying to remove injection pump
Old Mar 29, 2014 | 04:29 PM
Ben84's Avatar
Default trying to remove injection pump
I'm trying to r&r the injection pump in a 2006 lbz. It seems that I'm going to have
to remove the intake crossover tube. Do I have to remove the turbo to get that
out? Do I have to remove the entire intake? Never worked on a lbz and not sure
I want to again! Thanks in advance
Old Mar 29, 2014 | 11:55 PM
2004LB7's Avatar
no need to remove the crossover tube.
two ways to do it without removing the tube.
1, remove the pickup gear pump on the back of the CP3 or
2, on the Y-Bridge (crossover tube) remove the front bottom and top bolts/nuts and tilt the Y-bridge back to get the needed clearance. it is supposed to be tight but some twisting and turning it will come out
you can get to the back bottom bolts on the Y-Bridge with a 10mm socket and swivel joint and extension
good luck,
Jason
Old Mar 30, 2014 | 04:16 PM
Ben84's Avatar
Thanks for the reply. I should have a little time tomorrow to try it out.
Old Mar 31, 2014 | 07:52 PM
Ben84's Avatar
Jason,
Thanks for the info! The back nuts on the crossover tube were a pain, but once that is removed there is plenty of room to remove the pump. Thanks again
Old Apr 1, 2014 | 04:02 PM
2004LB7's Avatar
great, glad you got it
ctjkelley
Jun 3, 2015 06:01 AM
nelly559
Feb 17, 2015 06:49 PM
moneypitk5
Feb 12, 2015 11:01 AM
letters4and18
Dec 11, 2014 12:03 PM
rtbcoop
Nov 29, 2014 11:33 PM
