Changed fuel filter won't start help please!!!
Old Mar 29, 2014 | 02:22 PM
CumminsPower95's Avatar
Default Changed fuel filter won't start help please!!!
I put a new fuel filter in and ran for maybe 3 seconds and died I figured there's air in the lines theirs no bleeder on the injection pump so I don't know what to do to get ge air out besides pull starting it and I'd rather not please help! On the injection pump theirs two valves one hose from the filter housing and one open one but theirs no bleeder to push the air out and I'm out of options any help would greatly be appreciated!!!!!
2001 cummins 5.9 by the way.
Last edited by CumminsPower95; Mar 29, 2014 at 02:22 PM. Reason: Automerged Doublepost
Old Mar 30, 2014 | 12:34 PM
AHolt's Avatar
Can you crack line at pump, and bump key to see if you have fuel at pump.
Old Mar 30, 2014 | 02:17 PM
buddyruss's Avatar
i dont know about that one but my 03 will self prime if you cycle the key till the engine bumps over without starting ive had to repeat this process 5 or 10 times before on a filter change
there is a video on you tube titled how to prime fuel system on 5.9 cummins its almost the same as my 03 but you actually have to drain the air /fuel out of the pressure test valve port
Old Mar 30, 2014 | 05:58 PM
I don't have that valve port on that video one port the housing hose is running to and the other one is open
Cavnar
Sep 9, 2015 07:18 PM
RatsMC
May 4, 2015 05:25 PM
Collin Dow
Feb 21, 2015 08:18 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
