fuel plate mod
Old Mar 28, 2014 | 05:58 PM
asd1211's Avatar
Default fuel plate mod
I am looking to grind my fuelplate down to a zero or flat and was wondering if this will affect the motor performance or cause excessive smoke. i drive a 97 ram 2500 12 valve. also if i do this and get an adjustible turbo conrtol elbow thing how would that affect it. Any advise is helpful.
Old Mar 28, 2014 | 07:05 PM
turbo2332's Avatar
super noob. welcome
yes it will smoke more yes it will be a factor in drivability, yes you will gain HP, it is called a boost elbow
advise is go for it, you have to start somewhere.
Old Mar 28, 2014 | 11:03 PM
sweetv8s10's Avatar
I would recommend that u get gauges first but that's just my opinion
Old Mar 29, 2014 | 06:03 AM
JBearSVT's Avatar
+1 on gauges first.
That said, unless you've gone into the pump (rack plug, etc, which it doesn't sound like you have) and you intend to grind your plate flat (irreversible), my advice would be to slide it all the way forward and drive it for awhile. Then just take it out. If you don't like it, put it back in and do some research on what profile to grind that will give you the compromise between the two extremes you'll have now experienced. It's easy to take out, easy to put back. Not so easy to un-grind.
Old Apr 2, 2014 | 04:33 PM
akcoalroller's Avatar
i second this^ i just took my plate out and did a boost elbow when i first got my truck. also did the afc mods aswell. makes a world of difference but you gotta have those gauges installed or else you may just have a bad day.
Old Apr 2, 2014 | 11:19 PM
4x4manonbroke's Avatar
All the above ... Blown Head Gaskets to boot ... have one for proof ...
Old Apr 3, 2014 | 10:48 AM
ebarresi5894's Avatar
...and I hope your tranny is good because it wont be after a week
Old Apr 3, 2014 | 10:56 AM
good point. i did my afc mods and removed the fuel plate, after that i did comp DVs and the tranny was toast after a rebuild 13k before. the trannys just dont hold up at all until you build them. great advice. plus its really spendy!
Old Apr 3, 2014 | 11:08 PM
12 valve dodge cummins's Avatar
bulb
First you should get your gauges and yes it will blow out more black smoke. You should also do your starwheel depending on your power gain.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
