2000 powerstroke wont start
Old Mar 16, 2014 | 06:45 PM
jaredg's Avatar
Default 2000 powerstroke wont start
just bought a 2000 powerstroke drove home no problems and parked it in the garage and went out the next day and would not start and was plugged in all night. put new cps, and idm, buzzed tested all injectors and they are all good and fuel pressure is good. I am all out of ideas what else should I do? not sure how the guy I got it from started it.
Old Mar 16, 2014 | 07:40 PM
joebob3093's Avatar
Moderator
Fuses good?
Old Mar 17, 2014 | 05:20 AM
jaredg's Avatar
yup no bad fuses also cranks fine and batts. are ok just wont fire
Old Mar 17, 2014 | 12:28 PM
joebob3093's Avatar
Moderator
Any codes? How's ICP?
Old Mar 18, 2014 | 05:28 AM
jaredg's Avatar
no codes icp working like it should
Old Mar 18, 2014 | 08:17 AM
deck60's Avatar
I am new to the ps diesel not sure what all your codes are
this is what happend to mine the day i got it plugged it in and went to start it the next am nothing found i had 1 bad batt and my block heater needed replacement you can check it with an ohm meter at the plug
i did a lot of research and the one thing I haven't heard said is does your glow plug light come on and have you checked all your glow plugs and relay
Old Mar 18, 2014 | 09:16 PM
jaredg's Avatar
block heater works and glow plugs tested good and wts light comes on. I was thinking the ipr would that make sence.
Old Mar 19, 2014 | 07:31 PM
deck60's Avatar
ipr would that be injection pump relay if so that would be a good start
Old Mar 19, 2014 | 07:54 PM
joebob3093's Avatar
Moderator
There in no injection pump on any power stroke. IPR is injection pressure regulator
Old Mar 19, 2014 | 07:57 PM
deck60's Avatar
so does this work off the high pressure oil pump then
