Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Limited slip additive...
Old Apr 11, 2007 | 10:18 PM
dieseljunkie's Avatar
Default Limited slip additive...
Ok, so I have seen that if you use Mopar approved fluid (a mopar part number) you don't need any limited slip additives with it. I would assume when using other fluids (I will be refilling mine with amsoil) that a limited slip would need the additive put in. If anyone can point me in the right direction before I make a purchase.. (I have at least a week before I purchase). No sense in telling me to use something other than amsoil gear oil.. I will be a dealer here shortly, and have always been a believer in their products I just gotta know if I should spend the extra $$ on the additive or not.
Scott
Old Apr 12, 2007 | 07:25 AM
Heath's Avatar
Authorized Amsoil Dealer
The additive is not required with most synthetics, although some put it in anyway. I did As far as the gear oil, are you going with 75W-90 or the new 110? The new 110 is a new grade that falls within the old 90 range, so you're still meeting the required specs of your vehicle, but on the high side, if makes sense.
Old Apr 12, 2007 | 09:00 PM
Hadn't decided that yet Heath... Was thinking about going with the 110, but I wasn't 100% on it yet.
Scott
Old May 8, 2007 | 11:03 AM
Duluth Diesel's Avatar
The Severe Gear already had the additive build in. AMSOIL sells their Slip Lock additive separately, but I've never sold a single bottle since it is already pre-mixed. I'd go with the 75W110.
-Chuck
Old May 9, 2007 | 09:36 PM
I was giving some serious thought to running the severe gear 110.. The radiator just puked in my daily driver toyota, so it looks like it will be a couple weeks before I can afford to do this anyhow. Thanks for the advise though.
Scott
Sep 15, 2015 07:40 AM
Jul 21, 2015 07:50 AM
easttn12valve
Ford Powerstroke 2011-Up 6.7L
Mar 1, 2015 08:21 AM
Feb 12, 2015 05:40 PM
Feb 12, 2015 03:00 AM
