Single Disk Southbend Vs. Valair
Old Mar 10, 2014 | 10:12 PM
CHIEFSAVAGE's Avatar
Default Single Disk Southbend Vs. Valair
I had a few questions regarding my options in buying a new clutch. I am swapping a 96 cummins and a nv4500 into my '88 GMC v3500. Upon inspection of my stock flywheel I noticed several cracks on the contact surface of where the disc rides. So I definitely need a new flywheel. I had a #10 fuel plate, afc tuning, and timing bumped a little in the dodge and had enough power I slipped the clutch a couple times so there is also mild heat damage to the flywheel and disc. I want to upgrade to THE Valair #NMU70279-01-5SCE, its the 13" flywheel and organic clutch kit. Most sites I look that sell this clutch kit claim 400hp and 900ft lb holding capability such as here>>> http://www.thoroughbreddiesel.com/va...79-01-5SCE.htm. But the Valair website only claims 350hp and 800ft lbs capability. My motor is balanced, rebuilt .40 over, tuned, and will push 36psi boost, I think with more fuel I will be on the up side of 350 hp. Will the Valair clutch hold the power? This is just a hunting, off roading, work on the farm, play around, tow the horses once in a while truck. Nothing serious. If I am going to spend the money I just want to do it right the first time thats all.
I am also considering the Southbend 13125-OK >> http://www.thoroughbreddiesel.com/so...d/13125-OK.htm.
Im not loyal to either company. But the Valair is $652, and the Southbend is $727.
So what do ya'll recommend?
Old Mar 11, 2014 | 06:06 AM
biged681985's Avatar
id just spend a little more and go dual disk from valair.
but if i was to pick a single disk, id go with a valair. installed several of them. lasted awhile on trucks in the 400hp range, till he towed a heavy *** load
Old Mar 12, 2014 | 01:03 PM
so your saying ill just burn through the Valair single disc is I dont turn my fuel down? Im thinking spending a little more and going with the Southbend.
Old Mar 12, 2014 | 02:12 PM
lukesdiesel's Avatar
I would go Dual Disc..... Valair
Luke
Old Mar 12, 2014 | 11:06 PM
yea I really had no money for a dual disc and I really did not need it. I just bought the 400hp South Bend Single Disc organic. I had $20 summit bucks so it only ended up costing me $707 shipped. It was only fifty bucks more than the Valair and I still don't know how much hp their clutch was rated for.
BIGHORN08
6.7L Performance
Jun 27, 2016 08:52 AM
broncobo43
Jun 28, 2015 08:32 PM
5.9sledhead
Price Quote - Request A Price
Apr 23, 2015 09:17 AM
