Where Can I find a Hydraulic Clutch Line?
Old Mar 10, 2014 | 07:39 PM
ZakAttack's Avatar
Default Where Can I find a Hydraulic Clutch Line?
I can't find a hydraulic clutch line that goes from the master cylinder to the slave cylinder anywhere. I have a 1987 6.9 f250 with the 4 speed tranny.
I accidentally cracked mine and I can't find a replacement anywhere!
Can anyone help? Any suggestions?
Old Mar 10, 2014 | 09:09 PM
4x4manonbroke's Avatar
you will be forced into buying the entire thing ans they are all 1 piece ...
I know the feeling there ...
Old Mar 13, 2014 | 01:11 AM
Sycostang67's Avatar
It's really weird, I couldn't find the line for your truck at O'reilly's website. I have got several clutch lines for my fords from there. I did some research though, your truck uses the same clutch master and slave(same part numbers for both applications) as an 85 F-250, which they do list a clutch hose for. It should connect your slave and master then. The only thing I would warn you about though is that there was a redesign of the clutch hydraulic system. I snapped the pushrod on the clutch master in my 93, when I replaced it, the hose wouldn't reach it anymore. They changed the angle the hose was supposed to attach at so I had to get a new hose as well. It couldn't hurt to get this hose and see how it routes in your truck. If the redesign went back to the 80's stuff, you may have to get a new master as well. Here is the part I found.
List: Clutch Hose - 1985 Ford F-250 | O'Reilly Auto Parts
Old Mar 25, 2014 | 08:51 AM
93blklightning's Avatar
Rockauto.com cheapest place I know. That's where I get mine
Sent from my XT907 using Tapatalk
Old Mar 25, 2014 | 09:09 AM
ZakAttack's Avatar
I got one off of an old truck at the junkyard. It works like a champ. I didnt even think to look on rock auto for some reason. I got the new line on though, along with a new slave cylinder. My only problem now is getting the clutch bled I pulled the slave and master and manually bled them and I have some pressure. But after I try to bleed it a little more to get it better, I lose everything..... what the deal?!?!
katman
5.9L CR Performance
Sep 10, 2015 03:34 AM
Turbo67
Jul 25, 2015 02:26 PM
|WYG|SS
May 7, 2015 04:57 AM
motormayhem
Nov 16, 2014 02:13 PM
Wyocumins
Oct 19, 2014 09:34 PM
