Mercedes Discussion of Mercedes Diesels
om617 head bolt lengths???
Old Mar 9, 2014 | 07:25 PM
Jordank520's Avatar
Default om617 head bolt lengths???
alight so ill give you alittle summary. I have a om617 motor swapped into a s10 and used as a rock crawler. I sank it in water one time sucked up water stalled lifted the head a blew the gasket i changed the gasket reused the original head bolts didnt know there was certain spots for the short, med, long head bolts i thought they were all the same.... well now my head gasket is leaking again can see it bubling out the head on the back passanger side. im gunna redo the gasket again and buy all new bolts. can someone tell me off the 22 head bolts which numbers are short, which are medium and which are long? thanks
Old Aug 28, 2014 | 07:42 PM
cumminsf150's Avatar
found your thread because im bolting the head on my cherokee and had the same question.
well after going and getting a beer i realized, the ones that hold the cam down are the long ones, the short ones all go on the side near the injectors, and the med size are the rest.
Old May 11, 2015 | 12:04 PM
atypicalguy's Avatar
Default This is the best om617 head bolt length
...thread in the entire world. Kudos.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
Oct 31, 2014 08:10 AM
