E4OD to t19??
Old Mar 6, 2014 | 06:52 PM
91 7three's Avatar
Default E4OD to t19??
My E4OD is starting to slip. I dont wanna pay for a zf5 speed, I dont have enough money. So I'd like to go to the t19. I know it'll probably get worse fuel mileage and everything but that doesnt bother me too much. So can anybody tell me (in detail) what I'm gonna need to pull this off? And roughly how much it'll cost if youve done it yourself?
Old Mar 6, 2014 | 09:18 PM
Dortiz's Avatar
Usually with the e4od if you think it's slipping 90% of the time it's electrical. Crawl under the passenger side, there will be a heat shield held onto the side of the transmission with 2 bolts, there is a plug behind it, willing to bet there is either bare wire showing, or the plug needs to be cleaned off. If there is wire showing they sell a replacement plug for that for this exact reason. Just me $0.02
Don't remember if your truck has it or not, but it should have Fuel Injection Pump Lever (FIPL) . From factory it is recommended they are replaced every 50,000 miles.
Old Mar 6, 2014 | 09:20 PM
91 7three's Avatar
Ok thanks I'll give it a shot. Still plan on doing a swap down the road sometime
Old Mar 6, 2014 | 09:37 PM
Dortiz's Avatar
If that fixed the problem, I would save up for a zf6 I'm looking to do that when my zf5 goes, if it ever does. I power shift it, run it half full, and still nothing.
Old Mar 6, 2014 | 09:44 PM
91 7three's Avatar
I just might. I was also considering maybe doing a 6bt swap down the road
Old Mar 6, 2014 | 10:19 PM
Dortiz's Avatar
Do you do a lot of towing? If you do, than just about the only reason to go 6bt over a 4bt, the 4 gives you better mileage aswell
Old Mar 7, 2014 | 12:22 AM
91 7three's Avatar
Yeah quite a bit. Not an insane amount but quite a bit. Plus for some reason 6bts are cheaper than 4bts where i'm at. dont know if thats normal or not
Old Mar 7, 2014 | 02:21 PM
4x4manonbroke's Avatar
the 4 is a great lil engine .... more for like a yoda or a crawler truck ... the 6 will get ya movin if your wanting more power and such ... mine is soon to be built as well ...
Old Mar 7, 2014 | 03:01 PM
91 7three's Avatar
sweet man. be sure to post some pics when ya get goin on it!
Old Mar 7, 2014 | 06:51 PM
my ^bt is in the process of build ... will make pics and such along the way ... check out my build 88 7.3 IDI ...
RSWORDS
Mar 19, 2023 04:36 AM
Jake9473
Jul 22, 2018 08:19 AM
F250MACH
Apr 26, 2015 05:19 PM
