Aftermarket Exhaust Manifold ??
Old Mar 5, 2014 | 03:52 PM
ROCKITV8's Avatar
Default Aftermarket Exhaust Manifold ??
Who has changed the exhaust manifold on a 2006 5.9 cummins ? what changed and did you like it? I am leaning to the BD Pulse Manifold. I am looking for lower EGT's and mileage.
Old Apr 30, 2014 | 08:29 PM
ROCKITV8's Avatar
No one ????
Old Apr 30, 2014 | 10:37 PM
Bigg Redd's Avatar
Kinda like to know myself. I went on the cheap and ported it myself, then I heat wrapped it as well as the hot side of the turbo. Turbo spools up much faster and also lowered EGTs a bit.
Old Jun 12, 2014 | 07:31 PM
4x4manonbroke's Avatar
Factory ones need all the help one can give them .. porting will help a bit, but be careful you dont get outta control, you will kill some of your spool..
Old Jun 13, 2014 | 08:22 AM
Bigg Redd's Avatar
I hear ya. I took my time at this. A buddy of mine ported his with good success. He lent me his tools and gave me pointers as I did mine. I just didnt jump into it blindly. I likely would have f#*ked it up for sure. Im a cheap bastard. I hear good things about those aftermarket manifolds. If mine ends up cracking, then i'll likely get one myself, but its been a few years now and so far no cracks. I will usually pull the manifold blanket, after towing my travel trailer, and inspect for cracks. None so far tho.
Old Jun 13, 2014 | 08:25 AM
AHolt's Avatar
If you are going to port your stock manifold, put gasket
over hole, color with marker. take gasket away and
grind away marker area. Just blend it in.
Old Jun 13, 2014 | 08:35 AM
Bigg Redd's Avatar
Yep, thats the way its done......
Old Jun 13, 2014 | 10:19 AM
Thats what I did with My IDI's Exhaust man. , Now I'm doing HG's ( not related ) .. just waiting on gasket set ...
I put a 3 pc on my Cummins 12V, Made a world of difference in spool and reaction time... Turbo gets lit fast now ..
Old Jun 14, 2014 | 12:13 PM
Bigg Redd's Avatar
I should probably look into an aftermarket again. Im quite sure an aftermarket still outflows a ported stock by a substantial margin. Im sure I can recoup some of the cost if I put my ported stocker on ebay or craigslist. Time to so some research.........
Old Jun 16, 2014 | 01:21 PM
Blair@BD's Avatar
FormerVendor
The exhaust manifold will help some, but you will not see huge drops in EGT's by just replacing the manifold (maybe 50 to 75deg) The chip tends to run a little hot so you would see better drops in EGT's by doing a turbo or the intercooler.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
Old12er
Feb 20, 2015 10:35 PM
cummins Pride
Oct 23, 2014 01:10 PM
