Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
08 chevy with efi live winter problems.
Old Mar 3, 2014 | 10:02 AM
tfunk22008's Avatar
Default 08 chevy with efi live winter problems.
Hey guys I'm stumped with a gelling issue. I've tried bottles and bottles of additive. The only thing that what screw me Is putting straight number 1 in. Im here in Nebraska and anytime it gets down to zero I can't go anywhere. But the weird thing is that my dads 07.5 just drove away this morning with no additive or anything and filled up at the sand exact pump. Is the efi live screwing with it? Or Is there something on the truck I should be checking. Any help would help thank you
Old Mar 3, 2014 | 10:33 PM
2004LB7's Avatar
fuel filter heater. check the currant draw of the wire going into the top of the filter housing
glow plugs
air intake heater
these are the things i would check first. i dont believe a filter heater problem will cause any check engine light but the latter too will
Old Mar 26, 2014 | 09:46 AM
BriteWhiteRam's Avatar
glow plugs
air intake heater
fuel filter heater? WHA?? not to my knowledge.... I live in Canada, and 99% of the time only straight #1 goes in my tank, no additives, no fuel filter heater, and I've never had an issue with gelling, sounds like a fuel problem to me
Anti-gel wont do much to fuel that is already gelled, the fuel has to be fluid so it can mix together, sort of like pouring anti-freeze ontop of ice, it wont melt the ice, you have to have liquid water before you add the anti-freeze to prevent the freezing
Old Mar 28, 2014 | 01:12 PM
2004LB7's Avatar
Duramax fuel filter heater is located in the filter housing head. it is powered buy a 15 amp fuse in the fuse box when the ignition is on. there is a snap switch in the filter head that will close when the temps drop below 59.8°F. the power wire connects to the top of the housing of the filter
more cold fuel info here
ULSD Cold Weather Information
heat is the most effective way to combat gelling
Jason
nomoney
13
Sep 26, 2015 12:04 AM
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
Cumminsmoney
6.7L Performance
Jun 26, 2015 12:59 PM
797Ram
Price Quote - Request A Price
Mar 9, 2015 09:36 PM
dirtymaxrens
Jan 24, 2015 08:02 PM
