bigger fuel pump needed with bigger fuel lines?
Old Feb 22, 2014 | 02:54 PM
ebarresi5894's Avatar
Default bigger fuel pump needed with bigger fuel lines?
Ok so I'm starting to build a sled puller 97 12v. And I'm curious to know of I put 1/2 fuel lines from the tank to the motor, do I have to run a bigger L.P.? I dont want to put a electric pump because I like the mechanical.
Any input is great thanks
Old Feb 22, 2014 | 05:37 PM
94 12valve's Avatar
why would you not want an electric pump? the stock lift pump wont keep up with the fuel demands for sled pulling. You could run a waterman its gear driven but your checkbook won't like it.
Old Feb 23, 2014 | 07:55 AM
Do you think an air dog 150 would work? I wanted to do the fuel system before injectors
Old Feb 23, 2014 | 08:49 AM
94 12valve's Avatar
what class are you building the truck for and what ppump will you be running?
Old Feb 23, 2014 | 09:42 AM
8500 class and its a 7100 185hp I wanna say. It already has 3gsk and 100fuel plate
Old Feb 23, 2014 | 10:58 AM
94 12valve's Avatar
if it is the 180 pump found in the 96-98 auto trucks put some 5k springs in and yes that 150 will work fine. Make sure you add the 40psi spring and get a good overflow
This is what I run on the truck you see in the vids if your truck is a puller only and your goin with an air dogg 150 this is what you also need to run.
CUMMINS RACE ONLY OVERFLOW VALVE OFV075HP - Tork Teknology
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
