Coolant Bypass Hose / Heater Core Routing Questions
Old Feb 11, 2014 | 11:03 PM
cviola2005's Avatar
Default Coolant Bypass Hose / Heater Core Routing Questions
I have been trying to find out everything I can about the coolant bypass hose. While I have learned quite a bit, I still have questions.
Can the bypass hose be deleted without adverse effects? I believe the hose is there to constantly circulate coolant through the block and heads, is it correct? If so, can I remove that hose and reroute my return heater core hose to the water pumps bypass hose inlet?
Any insight and help is greatly appreciated.
I just thought of something else. The main problem with this engines cooling ability is the rear of the heads, correct? If so, couldn't that be caused by the fact that there is no crossover between the heads in the rear?
How's this for an idea?
Drill a hole into each crossover blockoff plate and weld in a bung for 3/4" NPT. Then install hose barb fittings and a "Tee" that then connects to the water pump's bypass hose inlet, in turn changing the bypass hose from the front coolant crossover to the rear of the heads.
This is my new idea, and I think I may try it unless someone else can say that they (or someone they know) has tried it. In theory, it seems like it would be better to pull hot water from a lower flowing area than the high flowing t-stat area.
A little more research shows (on another forum site) that Racer55 was considering something similar with the crossover plates a few years ago. And that a few other people have discussed it, but nothing became of it.
Anyone care to discuss this? Better off modified, right?
Last edited by cviola2005; Feb 11, 2014 at 11:03 PM. Reason: Automerged Doublepost
Old Feb 13, 2014 | 05:09 PM
cviola2005's Avatar
More research last night showed a company that still makes a kit with this in mind. I will probably be making my own to connect the plates to the heater core line off of the t-stat housing. I will be restricting the flow from the t-stat housing so that it will increase flow from the rear of the heads.
Old Feb 13, 2014 | 06:28 PM
jrsavoie's Avatar
I thought of doing something similaR years ago, but never got to it. I think we were just going to run a line from head to head.
Doesn't SS diesel sell a kit that does something like this?
How do the lines run in the kit?
Old Mar 6, 2014 | 04:52 AM
Drot drot's Avatar
Drilling holes in the blanking plates is the go blokes are doing that over here in oz on these engine conversions work a treat.
Old Mar 6, 2014 | 11:28 AM
cviola2005's Avatar
I have them made and installed, but have yet to run the engine with coolant. I have a 3/8" rubber line coming from each head to a tee in the middle. the center leg of the tee runs under the intake and IP around to the passenger side port on the water pump.
Old Mar 7, 2014 | 12:37 AM
racer55's Avatar
Most folks who did the rear flow idea years ago returned the coolant to the heater core return line.
94_12v
Mar 21, 2015 10:11 PM
ramrunner01
Mar 19, 2015 11:03 PM
Detroitdiesel97
Mar 10, 2015 06:02 PM
94_12v
Feb 11, 2015 11:38 PM
JustAnother_cummins_guy
13
Oct 29, 2014 12:48 AM
