no pedal after certain load 96 12v
Old Feb 7, 2014 | 03:24 PM
muddyold7.3's Avatar
Default no pedal after certain load 96 12v
my 1996 12valve has been running fine but when i get to a certain speed or rpm i push the pedal and it does nothing almost seems like it bogs down a little bit can anybody help ?
Old Feb 7, 2014 | 04:55 PM
mysterync's Avatar
Have you checked the external throttle linkage and cable? Are you located in a cold climate currently?
Sent from my SCH-I605 using Tapatalk 2
Old Feb 7, 2014 | 05:48 PM
Checked tge throttle she feels good and it's chilly around here 50-20s
Old Feb 7, 2014 | 05:53 PM
sweetv8s10's Avatar
What rpm are you at when it does this and when is the last time you changed your fuel filter?
Old Feb 7, 2014 | 07:31 PM
4x4manonbroke's Avatar
sounds like the cable is jaming up in the cover ...
Old Feb 8, 2014 | 10:45 AM
Hmm what could I do to fix that I don't think wd40 will get me outta this one
It's around 2 grand and I'm going to change the filter today
Last edited by muddyold7.3; Feb 8, 2014 at 10:45 AM. Reason: Automerged Doublepost
Old Feb 8, 2014 | 04:17 PM
I would make sure that the linkage is getting the full throttle ... you may end up needing a new cable ... but verify that you able to get WOT first .... have someone in truck push slowly to floor ... look for jaming or obstructions ... If you see none ... buy new cable and should eb good to go .
they usually come apart inside the cable sheeth ...
Old Feb 8, 2014 | 08:03 PM
sweetv8s10's Avatar
If it still has stock governor springs at 2000 rpm I wouldn't think it would have a lot left to give and that might be why it feels like it is bogging down maybe someone else will have a different opinion
Old Feb 8, 2014 | 08:21 PM
mysterync's Avatar
X2
Old Feb 8, 2014 | 09:59 PM
12vcumminspower7's Avatar
Just got done having this same EXACT problem,fuel filter was the culprit,but could also be low fuel pressure to the injection pump
