Starting still a problem!!??
Old Feb 5, 2014 | 05:20 PM
Bashore Farms's Avatar
Default Starting still a problem!!??
I have a 96 12 valve cummins. Can't figure this out. I go to start it and I have to hold my key the whole way (like to start) for about 5-10 seconds before I let it go or it'll die. Idle is set 900 or little above and brand new fuel filter. Need help. It'll start if I do what I said and then it'll run fine. Need some advice
Old Feb 5, 2014 | 11:42 PM
12vcumminspower7's Avatar
How many miles?Ever replaced lift pump?Any clicking noise when idling?
Old Feb 6, 2014 | 06:58 AM
Has 232,000 on it. And I've had it for about 3000 miles and haven't replaced lift pump
Old Feb 6, 2014 | 10:18 AM
akcoalroller's Avatar
Checked the bolts on the shutdown solenoid? If you ever removed the AFC the bolts may have worked themselves back out.
Sent from my GT-I9300 using Tapatalk
You can also get under the hood, pop the fuel filter housing, look inside of it, make sure the orings are OK and that the filter is OK then put it back on, prime it up real good and try it again. If its losing prime you may have a larger problem on your hands.
Last edited by akcoalroller; Feb 6, 2014 at 10:18 AM. Reason: Automerged Doublepost
Old Feb 6, 2014 | 11:27 AM
I just don't get why if I hold the key a couple seconds after it starts up it'll keep running but if I don't it'll die. Once I do that it runs like brand new. Is my key switch shorting out or not working totally?
Old Feb 6, 2014 | 11:35 AM
Any harsh clicking noise when idling?
Old Feb 6, 2014 | 11:39 AM
Nope not that I can hear. I mean I don't listen real close but I had my hood open yesterday when it was idling and I was just checking things and let it warm up and it sounded good. I'm around cummins engines all day with the farm and it sounded normal. This just puzzles me.
Old Feb 6, 2014 | 11:45 AM
Could be a bad lift pump,bad banjo bolt,shutoff solenoid it half open,or bad fuel heater!
Old Feb 6, 2014 | 11:52 AM
Which banjo bolt you talking and where they at? And where exactly is the shut off solenoid.
Old Feb 6, 2014 | 11:56 AM
The one either going from the fuel filter to the injection pump or the return valve which is closest to the intake manifold towards the front of the truck on the pump.Shutoff it bolted on to the AFC housing.
