92 f250 2wd 7.3 idi
Old Feb 3, 2014 | 04:13 PM
teddygirone's Avatar
Default 92 f250 2wd 7.3 idi
i have a 92 f250 7.3 idi i had to replace a foot section of fuel line with rubber fuel line. the fuel filter went half dry i pulled it off 3/4 times and had to fill the filter up from half and the truck will run for a second then drain the filter half way and shut off. i keep topping the filter off with atf but it wont stay full how do i fix this. is it possible that air is still in the line
Old Feb 4, 2014 | 03:26 AM
97cummins's Avatar
Yes it is possible there is air in the lines. But it also sounds like your lift pump may have an issue. I would get that checked out.
Old Feb 4, 2014 | 10:32 AM
powerstrokin350's Avatar
I would definitely say lift pump, or, how low is the fuel tank, I'm having pick up tube issues so mine doesn't get fuel out of the tank once it's below 1/4 tank. If your lower than a 1/4 tank you may also be having pick up tube problems in your tank, the last part is plastic and they dry out and crack.
Old Feb 4, 2014 | 12:11 PM
ok thanks. i'm gonna start by putting a gauge on the shader valve. if i get a good reading im gonna try cracking the injectors... how common is it for the lift pump on these truck to crap out and can air cause the lift pump to die
Old Feb 4, 2014 | 01:21 PM
Dortiz's Avatar
Very common for the lift pumps to crap out, Installing an inline electric pump would be a good move
Old Feb 6, 2014 | 02:01 PM
i'm only getting 1.5 pounds at the shader valve on top of the fuel filter to my under standing it should be 5/6 i'm not to sure but i'm just gonna change the lift pump. how hard and long of a job should this be
92 f250 2wd hd
Old Feb 6, 2014 | 04:01 PM
bigjohn's Avatar
A depends on what your doing I just put a electronic one one mine took about 2 hours and 4 beers so if you get right to it problem a hour to change the Manuel one to manual about a half hour
Two bolts 9/16 I think and two lines ones a hose clamp the others a 5/8 steel not hard but dirty
Old Feb 6, 2014 | 09:10 PM
Dortiz's Avatar
It will be hard just due to the fact that it's an awkward place. Other than that it is straight forward
forgot to add that a healthy lift pump should put up to about 4-6 psi, an below and should replace
Old Feb 6, 2014 | 09:26 PM
did the lift pump and im only reading 3 pounds but its still airbound... how hard is it to go about bleeding the injectors one by one
Old Feb 6, 2014 | 09:45 PM
4x4manonbroke's Avatar
sounds like air intrusion to me ... do you still have the filter below drivers door on frame ?
also an electric pump should feed about 8-10 psi @ fuel filter inlet ..
It sounds to me like either one of two things .... pinched fuel line or fuel shut down sloenoid in IP is weak and not allowing it to stay running .. even with just 3 psi it should at least idle ...
