BD Power Transmission / Going In & Out of Lockup on the freeway HELP Please
Old Feb 1, 2014 | 09:36 AM
bkoso85's Avatar
ATTN BD Power Transmission / Going In & Out of Lockup on the freeway HELP Please
Need some help. 94 2500 BD Power transmission. It just started going in and out of lock up when I'm cruising on the freeway. It will go out then go right back in. It will do this at pretty much any speed above 50. As long as its a steady speed.
I have checked fluid level and it's good. Not burnt. Nice and clean. Any help would be appreciated. I have checked all battery cables and they are tight. Alternator is good.
Old Feb 1, 2014 | 10:07 AM
leakin 12 valve's Avatar
Mine has done that for a while but it's a stock tranny and tc but I am under the impression it's a sign of a failing tc
Old Feb 1, 2014 | 10:08 AM
bkoso85's Avatar
Never heard of that. I have been told it could be a bad or failing TPS, or RF Interference with the Alternator.
My Tc is only a couple months old also.
Old Feb 1, 2014 | 10:57 AM
4x4manonbroke's Avatar
Speed sensor or tps can cause that issue ... do some diag ... I believe its 5v from tps @ idle ?? cant recall exactly ...
Speed sensors are cheep .. Car Quest 28 bucks ... tps is like 93 ?
Old Feb 1, 2014 | 10:58 AM
bkoso85's Avatar
TPS is $130
Old Feb 1, 2014 | 11:00 AM
A Speed sensor or the tps could be the issue ...
Old Feb 2, 2014 | 11:28 AM
JasonQuartermile's Avatar
Probably the TPS...you can just bypass it and put in a manual lockup switch so it will stay locked. Just have to ground a wire. Unfortunately I did mine so long ago I forget which one. If you do this, always remember to unlock the converter when you slow down!
Old Feb 2, 2014 | 12:48 PM
12vcumminspower7's Avatar
1v at idle
Old Feb 4, 2014 | 02:08 PM
Blair@BD's Avatar
FormerVendor
It sounds like its the Apps check out the attached link.
BD Power - Product: APPS Noise Isolator
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
