Looking to make 600hp. What else do I need?
Old Jan 25, 2014 | 05:07 PM
Killacams's Avatar
Default Looking to make 600hp. What else do I need?
I'm looking to make 600 hp and everything that's done to my truck is in my sig. Just recently bought an air dog. And I know I need a set of DV's but not sure which ones to go with. Any suggestions will be appreciated
Old Jan 25, 2014 | 05:16 PM
mysterync's Avatar
7mm dv is the best all around valve I've found.
Sent from my SCH-I605 using Tapatalk 2
Old Jan 25, 2014 | 06:10 PM
94 12valve's Avatar
set your air dogg around 40 psi
Than put your DV of choice in, bump your timing up more, and dyno to see where you are at.
Old Jan 27, 2014 | 06:32 PM
Killacams's Avatar
Appreciate that fellas.
Old Feb 2, 2014 | 11:33 AM
JasonQuartermile's Avatar
I made 601rwhp with a 160hp pump at 28 degrees, lift pump, 57/71mm twins, 5x18s, and full cut dv's....although the 024's made 596 with a LOT less smoke.
I'd say with the better pump, you should be close with more timing and delivery valves.
Jul 21, 2015 06:50 PM
tbreddiesel
Contests And Give Aways
Jul 21, 2015 07:28 AM
Apr 30, 2015 01:10 PM
cumminsbred01
10
Jan 14, 2015 10:28 AM
Da Bomb
Diesel Engine Conversions
Dec 23, 2014 08:03 AM
