ether questions
Old Jan 24, 2014 | 05:54 PM
Billy D's Avatar
Default ether questions
My truck won't start again. Always when its real cold. I know its not a good thing, but should I try ether? Just a small shot to see if it fires, and where exactly should I squirt it. I've heard bad stuff and I really don't wana do it but I've read others doing it with no problems in a very small amount.
Old Jan 24, 2014 | 06:28 PM
JBearSVT's Avatar
How cold?
Old Jan 24, 2014 | 06:35 PM
Billy D's Avatar
It's right in the wind too, feels colder for sure
Old Jan 24, 2014 | 06:37 PM
mysterync's Avatar
Make sure if you do that you remove the grid heater relay feed wires from the battery! My recommendation would be start by testing battery voltage to get an idea of their condition, next verify you have adequate cranking speed, if you do verify you have fuel. Cold weather isn't to big of a hurdle if we take the proper steps to prevent starting troubles.
I'm also curious about what type of temps your seeing. Had a few come in and call for no starts today with 6am temps at -6f!
Sent from my SCH-I605 using Tapatalk 2
Old Jan 24, 2014 | 08:12 PM
Billy D's Avatar
It's still 12 here, 2 small squirts of ether and it fired right up. I need to test my grid heater, relays I guess. Its been no start these last 3 times its dropped in the single digits, except this time.
Old Jan 24, 2014 | 08:24 PM
turbo2332's Avatar
what is your idle speed? do you have to give it a little pedal to get her to go? if so bring the start fuel up just a bit. my 95 hadn't ran in a week parked in the field, 0* 2 days ago, two cycles with the grid heater and lethargically through the molasses like oil fired right up.
Old Jan 24, 2014 | 09:09 PM
six speed's Avatar
my 97 started this morning at 3 degrees on the first try. I was told that if you were going to use ether you should crank until the oil pressure comes up then it is safe. I also know a guy who blew his air box off and knocked the cap off his coolant tank on his 06 by using ether through the air box.
Old Jan 24, 2014 | 09:54 PM
JBearSVT's Avatar
Mine has been starting fine on the the second try all week, 5 below every morning. I haven't been plugging it in either, since I shorted out the block heater last year
Still, 12 degrees should be no problem unless something else is wrong. Or you have it timed to the moon...
easttn12valve
Ford Powerstroke 08-10 6.4L
11
Apr 15, 2015 09:47 PM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
