first real cold start ?
Old Jan 24, 2014 | 08:27 AM
bigjohn's Avatar
Default first real cold start ?
I just replaced all injectors glow plugs and turned my pump up a flat started good in the garage several days in a row cold moved her out side and next day np start weather is freezing here at -4 wind chill -25 is it the cold or the truck?
Old Jan 24, 2014 | 11:56 AM
Sycostang67's Avatar
Can you tell if the glow plugs are cycling normally, are you getting any white smoke out the tailpipe while cranking?
Old Jan 24, 2014 | 02:51 PM
bigjohn's Avatar
I didn't see any but I ingadged the glow plugs three times and put a batterie charger on it cranked for a few min fired up let her run for about 20 min sounded good drove 2 miles spit a little bit and died had her towed home don't know what the bill is going on I'm putting a electric pump on her now eliminating the old Manuel one
Old Jan 24, 2014 | 04:04 PM
powerstrokin350's Avatar
So, you heard the clicking after they ran, that's them cycling to aid in startup. I found this:
Diesel fuel #2 should resist gelling down to about -10 deg. F (-23 deg. C), while winter blends of diesel fuel #2 and fuel #1 (kerosene) can typically handle temperatures down to -4 degrees F to -20 deg. F. But some "winter" blends may gel at higher temperatures if it contains too much #2 diesel and not enough #1 (say around 18 to 20 degrees F).
Do you think your fuel may have gelled?
Old Jan 24, 2014 | 04:44 PM
Dortiz's Avatar
That's what I was thinking, never not (double negative for those who wanted to know) use fuel additive in these trucks.
Old Jan 24, 2014 | 06:34 PM
bigjohn's Avatar
i have been running power service 911 additvie to keep the fuel from gelling up but i cant remember if i added any at the last fill up i may not have , yes i do hear them cycling i am doing the electric pump tonight plan to finish it in the am i also added some 911 to the fuel hopefully thats it
Old Jan 25, 2014 | 02:25 PM
4x4manonbroke's Avatar
yeah get some 911 in ur tank and allow it to sit for a bit then if u can oulk it in somewhere where it can ungel over night ..... keep up on the911 or howes fuel lubricator ..... something to help ...
Old Jan 26, 2014 | 09:04 AM
bigjohn's Avatar
I got it out of the cold added some 911 and electric pump started and seems to be running good so far but scared to drive her to far yet going to try to get the front end changed out not sure what all I'm going to need but I'm going to give it a go
Ok not starting agin this am wtf I have new glow plugs I'm replacing the control box if that dose not work dose anyone know how to toggle switch it to by pass ? I know the 6.5 Chevy you could
Old Jan 26, 2014 | 11:37 AM
I found this on another forum.
ONCE AGAIN IT'S TURNING COLD AND I'M SEEING POSTS ABOUT HARD TO START AND GLOW PLUG ISSUES.I'VE BEEN THERE AND HAD THE SAME PROBLEMS AS SOME OF YOU OTHERS.WELL I FOUND SOMETHING THAT HAS WORKED GREAT FOR ME AND SAVED $$$$ ON GLOW PLUGS,IT'S A MANUAL CONTROLLER FOR THE GLOW PLUGS,GIVES ME CONTROL OF WHEN THEY ENERGIZE,SO THEY DONT CYCLE EVERY TIME I START THE TRUCK,ONLY WHEN I ENERGIZE VIA A PUSH BUTTON SWITCH,OK I'LL QUIT TALKING AND POST THE INFO. GO TO EBAY MOTORS TYPE IN ITEM#320800599383 INTO THE SEARCH BOX HOPE THIS WILL HELP SOME GUYS OUT.
Looked it up and they run $28.99+$8.95 shipping
Old Jan 26, 2014 | 11:50 AM
Dortiz's Avatar
Here's a funny question...how old are your return lines? and how many miles on injection pump, and injectors. I had to turn down the fuel screw on my ip cause it was dumping to much in (I was a rolling cloud ) and now have a harder cold start, may be your problem
