I need help!
Old Jan 19, 2014 | 09:59 PM
av8r's Avatar
Default I need help!
I have a 2000 f-350 with a 7.3 . When I put my foot in it after a few seconds the "check engine light" comes on and it seems to loose power, it kinda smothers out and runs sick. if I switch the key off then back on the "check engine light " goes out. it seems to run fine until I press the accelerator down pretty firmly. I have replace the cam position censor and this didn't help, also it doesn't show a failure code at all. anyone have any ideas??? oh... I have replaced the fuel pump and dropped the tank and cleaned the screens,
Old Jan 19, 2014 | 10:18 PM
joebob3093's Avatar
Moderator
Your running out of high pressure oil
Old Jan 19, 2014 | 10:50 PM
diablo2dusk's Avatar
may be your injection pump.
Old Jan 19, 2014 | 11:08 PM
joebob3093's Avatar
Moderator
Powerstrokes dont have injection pumps
Old Jan 20, 2014 | 06:15 PM
av8r's Avatar
That makes since but what would cause a loss of high pressure oil??????
Old Jan 20, 2014 | 06:17 PM
joebob3093's Avatar
Moderator
The 2000 engine runs AD code injectors and they love oil. Your oil pump could be weak. Is it chipped or have any programing?
Old Jan 20, 2014 | 06:50 PM
av8r's Avatar
not that I am aware of.... it blew two high pressure hoses a few months ago and I had a hose made using high pressure hydrolic hose
I'm sure it is all stock.
Old Jan 20, 2014 | 06:59 PM
joebob3093's Avatar
Moderator
Your pump might be getting weak, need a scanner to see
Old Jan 20, 2014 | 07:14 PM
av8r's Avatar
is that something that I can have done at the ford dealership or what would u recomend?
Old Jan 20, 2014 | 07:37 PM
joebob3093's Avatar
Moderator
They could do it, I dont like going to dealerships. Where are you located?
