Replace lift pump or wait?
Old Jan 15, 2014 | 10:20 PM
12vcumminspower7's Avatar
Default Replace lift pump or wait?
My truck has 200k miles on it and my lift pump has been acting up,Should i change it or wait till it goes out?And with a lift pump going bad can this affect performance of the truck?
Old Jan 15, 2014 | 10:39 PM
deck60's Avatar
the stock lift pump on my 98 I had issues and after the 3rd one I used one of these pumps and have not looked back works great
2 things to make sure you do put in a cheap inline fuel filter before pump it is a gear pump and after a few years the o rings might leak from diesel fuel otherwise they work great i would take out all lift pumps for these
the stock pump is like 110 gph @9-12 psi @ 1800 rpm so these are real close
http://www.ebay.com/itm/High-Flow-Performance-Electric-Fuel-Pump-140GPH-Universal-Fit-3-8-NPT-Ports-/330873921560?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d099f6018
Old Jan 15, 2014 | 11:07 PM
High Flow Performance Electric Fuel Pump 140GPH Universal Fit 3 8" NPT Ports | eBay
Awesome!
Easy to put on and all that fun stuff?And do i need to buy a lift pump replacement cover also?Where would i locate this pump also?
Old Jan 15, 2014 | 11:09 PM
sweetv8s10's Avatar
What do you mean by acting up?
Old Jan 15, 2014 | 11:11 PM
deck60's Avatar
I made my lift pump delete plate out of a 1/4 piece of steel on the dodge it was mounted on the frame rail just above brake line that goes to the wheel
Old Jan 15, 2014 | 11:15 PM
Clicking,hard starts,long time to start,etc.
Where do i mount the lift pump?
Last edited by 12vcumminspower7; Jan 15, 2014 at 11:15 PM. Reason: Automerged Doublepost
Old Jan 15, 2014 | 11:16 PM
deck60's Avatar
look on the frame right where the brake line goes to the front wheel there is a hole in the frame I just used a homemade bracket just get it as low as possible for sucking from the tank
Old Jan 16, 2014 | 07:36 AM
mysterync's Avatar
Just like to add my thoughts.
Most of the cheaper pumps cannot sustain the p7100 pressure needs for long, they often fail within a couple years.
If you intend to install a eletric pump I'd recommend that you look at a fass or air dog unit. I honestly feel installing a electric pump is a waste of time and money until about 500+rwhp. Above 500 is where you start to see pressure drops.
In factory applications we reinstall the cummins pump and offer a 3yr/36,000 mile warranty. I've yet to replace one a second time. When replacing the pump with the electric pump it's ideal to switch to a fixed orifice overflow valve which will keep fuel pressure stable throughout various conditions.
Sent from my SCH-I605 using Tapatalk 2
Might recheck those pressure specs.
Old Jan 16, 2014 | 08:45 AM
deck60's Avatar
and what are your specs i got mine from cummins when its -30 and a pump goes out that was the last straw this pump works great I rum about 14psi all the time my pump is never starved and 36000 is not much warranty that's 1 year or less of use my pump has over 100k use that's better than the stock ones i was using and better psi and it runs better too
Old Jan 16, 2014 | 09:00 AM
mysterync's Avatar
Sounds like someone gave you vp specs.
And just a note in regards to your thoughts on our warranty. We don't just sell parts, we are a full service shop. When we install the product all aspects are tested from tank restriction and cam wear to after completion fuel pressure test. That being said when i say we offer a 3yr/36k warranty it covers labor and diagnosis. The whole 9 yards. That warranty exceeds most manufacturer shops as well as indies and from my research most warranties of this nature are capped at 36k. Very few shops offer anything higher. The majority are 12mo/12k. I did see some that offered a 50k warranty but in those instances they charged extra for the warranty.
HeavyChevy95
Dec 21, 2016 10:36 PM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
