Boost Not Blowing Off
Old Jan 14, 2014 | 11:44 AM
12vcumminspower7's Avatar
Question Boost Not Blowing Off
I was coming up a hill yesterday and mashed on it and got the PSI up to 28 and it wont blow off unless i let off!Any input would be great!
Old Jan 14, 2014 | 02:17 PM
94 12valve's Avatar
if your looking for less boost you will need to moddify your wastegate ... but 28 psi is not an excessive number
Old Jan 14, 2014 | 04:13 PM
With my stock wastegate I was hitting 18-20 psi!
I purchased a bighead wastegate did the adjustment to make it blow off around 30,but would only go up to 23psi!
Pinched it off to see the max and it hit 32psi!
Then I bought an adjustable elbow have it about a quarter way out and it wont blow off or shift unless i let off?
I want around 32-35psi,but also want it to blow off and shift without having to let off!
Old Jan 14, 2014 | 08:20 PM
Benjamin's Avatar
Bombardier
I don't understand your terminology of "blow off".
A "blow off" valve is not factory equipment on that truck so there will be no "blowing off".
if you want more than 32psi, put a turnbuckle on the wastegate to disable it's function. but this will put stress on a stock turbo and ultimately lead to a premature death of the bearings and shaft.
Old Jan 14, 2014 | 08:49 PM
94 12valve's Avatar
why do you want to fall under the turbo every shift?
Old Jan 14, 2014 | 10:09 PM
It won't shift in to the next gear after it builds up boost,What i meant as in blow off,release the psi sorry!
Old Jan 15, 2014 | 07:43 AM
Benjamin's Avatar
Bombardier
you never want it to release the PSI between shifts.
if the trans isn't shifting at WOT, it is a TPS or a transmission issue, not a turbo or wastegate issue.
Old Jan 15, 2014 | 03:20 PM
TPS?
Old Jan 15, 2014 | 03:54 PM
Bigg Redd's Avatar
TPS is not really as bad as it sounds. But, if its the trans, thats another issue all together.
Old Jan 15, 2014 | 10:16 PM
One day it would shift normal!Pinched off the wastegate then it wouldn't shift?
Sound like a TPS?
