Diesel Down
Old Jan 8, 2014 | 11:29 AM
lmays's Avatar
Default Diesel Down
I have a 04 F550 w/6.0 after setting in -18 deg.weather it wouldnt start I figured fuel gelled I have now had it inside for 2 days and still wont start it cranks fine but no fire voltage at ficm is 49.2 volts it will try to fire with a short shot of either. vehicle ran fine till it sat out in the sub zero weather
Old Jan 8, 2014 | 06:43 PM
AFRenoughsaid's Avatar
Did you check fuel pressure? It could have lost prime.
Old Jan 10, 2014 | 07:47 AM
lmays's Avatar
yes fuel pressure was at 46 psi & fills bowl in seconds I think I have found the problem but the cause is still unknown. I removed the IPR from the HPOP and found the screen sucked into the valve,I will replace it today & post the outcome
Old Jan 12, 2014 | 01:11 AM
lpnsteve's Avatar
Hmm
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 28, 2015 11:45 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
