Kubota V2203 Glow Plugs. Has anyone Hooked them UP?
Old Jan 4, 2014 | 12:04 AM
JesterGrin_1's Avatar
Default Kubota V2203 Glow Plugs. Has anyone Hooked them UP?
I wanted to ask if anyone has hooked up there Glow Plugs on there Kubota V2203 DI Engine?
I have read that it was not needed. But I thought heck if we have them how hard would it be to hook them Up?
Something simple like a push button switch with a light. The Glow Plugs are only on while holding the button down.
I found this thread ----> https://www.dieselbombers.com/chevro...-operated.html
But I am not sure why the OP said ( I only suggest installing this if you have self regulating glow plugs? ) Unless someone was to leave there thumb on the button for too long it could be bad for the Glow Plugs.
Old Jan 4, 2014 | 03:06 AM
redveloce's Avatar
I hooked mine up. I just used a lawn tractor solenoid to power them, and put a push button on the column right above the ignition. No need for a light, I can hear the solenoid click very clearly. Also, it's handy for timing reference that my airbag light stays lit for exactly 10 seconds.
Sent from my Nexus 7 using Tapatalk 4
Old Jan 4, 2014 | 08:23 AM
usedkubotaman's Avatar
Same here, I used a simple 30 amp relay and a push button. Though the engine will start without glow plugs I believe it makes it easier on the engine if you do use them.
Old Jan 4, 2014 | 11:10 AM
FTE's Avatar
FTE
Same here, I have only used them below 20 deg F. I haven't hooked the up proper, just a jump wire, next on the to-do list. It will start without, but as kubotaman said it just starts easier.
Old Jan 5, 2014 | 12:45 AM
Thanks Guys.
I was thinking of something very simple as I am sure in South TEXAS it will not be needed all that often.
Metz1234
Mar 3, 2016 10:20 PM
rkp209
Chevy/GMC Duramax 2011 LML
Jan 10, 2016 10:32 AM
GT_Eleanor
Sep 14, 2015 10:52 AM
1997silverado
Mar 12, 2015 07:40 PM
hardwired
8
Jan 23, 2015 04:30 PM
