Engine Grounds
Old Jan 1, 2014 | 05:34 PM
CARP's Avatar
Default Engine Grounds
I am suspecting a bad ground somewhere on my truck. My radiator has sprung pinhole leaks on the tanks multiple times over the past year or so. I read up on a process called electrolysis, where stray voltage in coolant causes these leaks. Anyway, it is causes by bad grounds. Does anyone know where the main engine grounds are? Has anyone else had this problem?
Old Jan 1, 2014 | 07:42 PM
Dortiz's Avatar
How are you at keeping up with the SCAs on your coolant? I believe it was a big problem around the 80's but sca's were usually the cure that they had
Old Jan 1, 2014 | 09:16 PM
4x4manonbroke's Avatar
yes SCA pre-charged coolant and yes electrolysis will happen when your pushing voltage through a block .... its accelerated when not running the correct coolant as well ....
Big grounds from batteries to frame and from frame to block on both sides of Engine , this should help stop stray voltage and electrolysis as well .... the batteries to frame wire should be much heavier than the wire from block to frame .... as a way of encouraging the voltage to take the path of least resistance ....
Old Jan 1, 2014 | 09:45 PM
CARP's Avatar
I am running proper coolant. Sca charged. The only grounds I can see are the ones on the left and right side on the front of the block. They look like the negative battery cables. Where are the others?https://www.dieselbombers.com/images...C_thinking.gif
Old Jan 1, 2014 | 10:20 PM
Dortiz's Avatar
I'll look for some, but did you try cleaning off the grounds?
Old Jan 1, 2014 | 10:25 PM
CARP's Avatar
not yet. I am in the process of soldering my radiator tanks. I will clean the two grounds on the front of the engine I can see.
Old Jan 1, 2014 | 11:33 PM
Dortiz's Avatar
sounds good
how's the grounding on your starter relay?
Old Jan 2, 2014 | 08:58 AM
CARP's Avatar
Is that on the fender well? The cables attached to the actual starter have corrosion on them. Could that cause it as well?
Old Jan 2, 2014 | 01:58 PM
Dortiz's Avatar
Very well could be the problem
Old Jan 2, 2014 | 08:24 PM
CARP's Avatar
Okay. .... I found a total of 4 grounds. Two on each side of the block from battery. One on left side behind lift pump to frame. And it looks like one on the drivers side head to the firewall. Are these all of them?
