Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
1995 International 4900 with the dt 530 looking for more power what are my
Old Dec 30, 2013 | 09:23 PM
94ifs's Avatar
Default 1995 International 4900 with the dt 530 looking for more power what are my
have an international the Ddt530 in the 300 horsepower model can I upgrade it what can I upgrade it to and what are my options looking to make it more fuel efficient but looking for around 400 horsepower. also it has a p pump.
Attached Thumbnails 1995 International 4900 with the dt 530 looking for more power what are my-p17r71bois1jv111a05ft1cgr148s3.jpeg
Old Dec 31, 2013 | 05:39 AM
yj junker's Avatar
truck will not be reliable or fuel efficient at 400hp ,I have a couple and just by plugging the wastegate line has helped ,as soon as you start turning up the pump they will smoke and get harder on fuel,running easy doesn't make much difference when you are moving alot of weight around but they can be turned up the same way as a normal p pump and will turn 2700 rpm and not cause much problems
Old Dec 31, 2013 | 10:19 AM
94ifs's Avatar
cool thanks for the reply you know the differences between the 300 and the 350 horsepower model?
Old Jan 2, 2014 | 09:44 AM
yj junker's Avatar
have not seen any 350 hp models but my guess would be injectors,timing and turbo size you can get bigger injectors ,aftermarket and larger turbo's but i have not tried anything to boost my power due to the cost of fuel my trucks haul gravel and asphalt and at the way our rates are we need the best fuel mileage we can get
Old Jan 2, 2014 | 11:24 PM
94ifs's Avatar
I haven't been able to find s*** online for injectors other than factory replacements.
Old Jan 4, 2014 | 04:01 PM
yj junker's Avatar
been a few yrs since I searched them but did find them somewhere
Old Jan 12, 2014 | 01:39 PM
nevrenufhp's Avatar
You can get your original injectors honed. The biggest OEM injector for a 530 is discontinued, so you can only get the replacement 300hp 530 injectors. Highest rating on the mechanical 530 is 330hp.
Great start is to do the free mods. Slide the fuel plate forward, and advance the timing a few degrees, then see how you like it.
Old Apr 16, 2014 | 08:27 PM
94ifs's Avatar
bump does anybody else got some more advice
Old Apr 16, 2014 | 11:33 PM
nevrenufhp's Avatar
I can't sign on as a different user, but I will get you in the right direction.
A customer of mine wanted to make a monster DT466(1995 also). To keep everything under one roof, the only place I could recommend is Industrial Injection. They did the pump, injectors, and turbos. He was setting up for 500-550hp for a toy hauler. The pumps in the 408,466,530 are a bit small, and Industrial has a great recipe for anything over 300hp.
Old Oct 4, 2014 | 09:16 PM
yj junker's Avatar
nevrenufhp ,having problem with your site link in your sig,won't load have used it before VERY helpful
