Delivery Valve Install
Old Dec 30, 2013 | 01:29 PM
12v HVY SMKR's Avatar
Default Delivery Valve Install
I will be installing delivery valves today and was wondering if there was any kind of torque on them or anything really that i should know about when installing them.
Thanks, Dan
Old Dec 30, 2013 | 03:24 PM
94 12valve's Avatar
torque the holder to 85 ft-lbs and make sure you don't cut the o rings. When your removing the holders be mindfull of the spring, shims, and poppet don't drop them or lose any. Re install just as you took them out its a pretty straight forward install just take your time and don't rush it.
Depending on the pump you may need a pick to remove the copper seal rings if there there.
RA113024
Mar 13, 2016 07:42 PM
Hutch58
Mar 21, 2015 12:13 AM
countryboy040993
13
Mar 5, 2015 08:58 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
