Hx40 vs he351 in compounds
Old Dec 27, 2013 | 06:33 PM
scottywiest's Avatar
Default Hx40 vs he351 in compounds
Which is better for towing? I already have hx 40 with s475, very fun setup with ddp150's and my setup. Would it be beneficial to swap to a he 351 for towing my 18k toyhauler. I also have 3.73's in the rear now. Thanks in advance
Old Dec 29, 2013 | 08:46 AM
Rooster24v's Avatar
have you tried to tow with your current setup? id try that first.
Old Dec 30, 2013 | 02:30 PM
jigabop's Avatar
he351cw would require changing your twin piping...
it would be cheaper/easier to change to a S300 turbo like a 57/65/12 or 57/65/14.
you could also go to a 62/65/12 or 62/65/14
the 12cm^2 housings will spool faster, but cost more.
14cm^2 housings are dime a dozen and very common to find.
either way they will definitely spool better than your hx40 with its 16cm^2 housing.
also any S300 turbo will last longer than the HX40 as they are built better and have MUCH stronger shafts.
Old Dec 30, 2013 | 06:36 PM
RAW's Avatar
RAW
I agree with Rooster. What are the results of towing with your current setup? We have similar setups, and I didn't break 1300* pulling my 39', 14,000 holiday trailer with a 16cm turbine housing on my hx35/40. Since dropping to a 14cm housing, the temps have slightly reduced and low end has increased.
DuallyDummy
For Sale
Jul 15, 2015 02:33 PM
Stox5225
May 18, 2015 06:01 AM
Dcummins24
Jan 4, 2015 12:51 PM
chuffysplace
Dec 20, 2014 11:22 PM
FlyingDutcman
Wanted To Buy (WTB) - Used
Nov 25, 2014 06:08 PM
