can somone please help me!! 91 dodge cummins
Old Dec 16, 2013 | 04:41 PM
let er eat's Avatar
Default can somone please help me!! 91 dodge cummins
Can someone please tell me what the rubberish plate on the block is for? Its located on the inside side of the inj. Pump on the block right behind the timing cover
Old Dec 17, 2013 | 12:54 PM
Sea97Stroker's Avatar
Sound proofing the lifter cover.
Old Dec 18, 2013 | 04:37 PM
let er eat's Avatar
Should it be something to be concerned about the front of the cover is starting to seperate from the block?
Old Dec 19, 2013 | 12:59 PM
u2slow's Avatar
The lifter cover... yes. That would create an oil leak.
The sound deadener.... no. That is only for noise abatement.
Old Dec 19, 2013 | 08:35 PM
let er eat's Avatar
Ok also have another question. When the truck gets up to temp,it will throw out steam and antifreeze out of the radiator but only for a few sec then goes away, a few min later it will repeat this process, any thoughts or suggestions?
Old Dec 23, 2013 | 09:51 AM
cumminsf150's Avatar
is this with the radiator cap off? or on? could be blown head gasket or cracked head.
Old Dec 23, 2013 | 11:20 AM
let er eat's Avatar
With the radiator cap on
Old Dec 24, 2013 | 09:37 AM
So I assume it's coming out of the overflow? Might be a bad cap.
Old Dec 24, 2013 | 11:35 AM
deck60's Avatar
when my head gasket was out you could see like boiling water in the radiator with the cap off and there was a faint green tint in the exhaust pipe if you looked it with a bright light
if your gasket is out a few things to be aware of
you will need to get it milled off and might as well have it gone through but not just any machinist can do a cummins head you need one that understands diesels and the way the valves are set back n the head
before mine would crank over 10-15 seconds before it would fire after my head was done mare 1 turn and it was running it is all in a proper done head
raude1
Apr 13, 2015 03:38 PM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
Linkbeltpower
For Sale
Dec 15, 2014 10:52 PM
Nov 4, 2014 08:10 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
