Lb7 heat!!
Old Dec 12, 2013 | 06:59 PM
mmaranto's Avatar
Default Lb7 heat!!
Ok. So here's the story. I got off of work one evening wet to get in my truck. All I did was open up the door with the keys in my hand. And the blower was blowing out cold air with the switch off n with no key in ignition and it smelled like a burning n wouldn't shut off. So I started the truck up and let it warm up for about fifteen minutes. When I got back in my truck the blower was off n wouldn't turn back on. Ever since then the only heat I have is if the vents are open instead of recirculating air. And yes that does get pretty warm!!! Any suggestion on what is wrong?! Anybody have this problem before?!?!?!
Old Feb 5, 2014 | 03:20 AM
Iroc-z's Avatar
Blower motor resistor and blower motor need replacement. You probably will need to wire in a new resistor harness because the old one will be melted.
Old Feb 23, 2014 | 09:46 PM
mmaranto's Avatar
Awesome! I'll sure be looking into that ASAP! Thanks!
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
auspot
Jun 30, 2015 05:57 AM
Walker.B
Show And Tell
10
May 10, 2015 09:34 PM
dshopex4
Chevy/GMC Duramax 01-04 LB7
14
Apr 15, 2015 09:40 PM
Oleoleson
Mar 28, 2015 06:20 PM
