Tranny won't line up
Old Dec 10, 2013 | 12:54 PM
james0048's Avatar
Default Tranny won't line up
I have a 2002 Dodge Ram, extended cab long box with the 5.9 cummins. I just swapped the original motor with another 5.9 out of either a 99 or 2000 Ram. When I go to hook the tranny back up it won't go all the way back in. After getting it all lined up it starts to go in then just stops about halfway. Any ideas?
Old Dec 13, 2013 | 11:25 AM
chimaira's Avatar
is your truck a manual or auto?
Old Dec 13, 2013 | 11:52 AM
james0048's Avatar
It is the 6speed manual. And a little clarification on the original post,the transmission goes into the splines and gets about an inch from being all the way in but then the input shaft wont go into the pilot bearing. It looks like its hitting high but nothing we do well get it to go in
Old Dec 13, 2013 | 11:55 AM
chimaira's Avatar
When you reinstalled the clutch disc and flex plate to the new motor did you use an alignment tool? Also are te pilot bearings the same size?
Old Dec 13, 2013 | 11:59 AM
james0048's Avatar
Yes I uses the plastic alignment tool that comes with a new clutch,and its the same size pilot bearing
Old Dec 13, 2013 | 12:07 PM
Moose's Avatar
Push the clutch fork in to disenguage the pressure plate from the clutch disk, this should let you get the input shaft where it needs to be. Those plastic alignment tools are sometimes a little bit off. Usually I just hook up the slave cylinder and push the clutch pedal in to release the pressure plate.
Old Dec 13, 2013 | 12:14 PM
chimaira's Avatar
^^what that guy said^^
Old Dec 15, 2013 | 10:15 PM
DalilaFetter's Avatar
i do not know by what the effective way the suggestion is going to work but i am too going through the same trouble why looking for it
Old Dec 19, 2013 | 01:34 AM
james0048's Avatar
Well I figured out what the problem was. Turns out the plate on the back of the motor that the transmission bolts too is over an inch thinner on the motor out of the 99. Swapped them and that transmission slipped right on in.
|WYG|SS
May 7, 2015 04:57 AM
Feb 12, 2015 03:10 PM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
motormayhem
Nov 16, 2014 02:13 PM
