injector stuck in cup
Old Dec 1, 2013 | 02:10 PM
bowdaddy121053's Avatar
Default injector stuck in cup
Is there a way to remove a stuck injector from the cup? The cup and injector both came out of the head together. Thanks
Old Dec 2, 2013 | 01:17 AM
97cummins's Avatar
I would think maybe hose around the injector and cup with a penetrating fluid and let it set for a while,
Old Dec 2, 2013 | 08:37 AM
Thanks, I'll give it a try
Old Dec 5, 2013 | 06:55 PM
six speed's Avatar
if you soak it and let it set you might be able use a vice similar to removing a u-joint. screw a injector line back onto it and adjust the vice to catch the outside lip of the cup then pull down on the injector. maybe tap on the tip with a rubber mallet or dead blow hammer, something soft to keep from damaging the tip (the injector has to be in good shape for the core refund) and you don't want to damage the cup either. just an idea i've never had one to get stuck in the cup yet.
beardeddiesel
May 25, 2015 04:32 AM
beardeddiesel
May 24, 2015 04:25 PM
