ts 6 pos chipp wont start 7.3
Old Nov 23, 2013 | 04:09 PM
cummins Pride's Avatar
Default ts 6 pos chipp wont start 7.3
hey guy i just bought my 2001 limited excursion 7.3l a ts 6 position chipp i cleaned the terminals good there all clean the truck just cracks no fire pull the chip out and it fires no problem anyone please help
Old Nov 23, 2013 | 06:04 PM
joebob3093's Avatar
Moderator
How much did you clean off?
Old Nov 23, 2013 | 09:44 PM
1999stroker's Avatar
You need to make sure all the silicone is off the terminals and I mean all. Then hit each one with a little scotch brite.
Sent from my DROID RAZR using Tapatalk
Old Nov 23, 2013 | 11:41 PM
lukesdiesel's Avatar
Did you order the correct TS Chip?
Luke
Old Nov 24, 2013 | 02:28 AM
thank you guys for the ones that commented helping and i figured it all out they sent me a blank ts 6 pos chipp that hasn't been programmed yet i have the programmed one on its way and the old one back
Old Dec 14, 2013 | 10:53 AM
tuey1911's Avatar
i would either clean the terminals on it again when i did mine i was cleaning them for about an hour just to make sure i got everything off....if that doesnt work send it back to get reburned just to be on the safe side
Old Feb 13, 2014 | 09:27 PM
dallas67's Avatar
Make sure you always disconnect your battery when installing a TS chip
Old Feb 14, 2014 | 07:57 AM
birdman01's Avatar
X2
Old Feb 14, 2014 | 01:01 PM
dallas67's Avatar
You need to clean the PCM board real good with a scotch brite pad and really take off all the pasltic coding. The chip is not making contact with the PCM and is it matched to your PCM from TS performance. you need to give them the number off the PCM so they can match it. On the PCM there will be a 2 number and a letter that is what they need. I think one of these is your issue
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Domrig13
Dec 12, 2014 01:24 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
Altonlee
Oct 20, 2014 01:56 PM
