6.5 timing injector pump
Old Nov 16, 2013 | 08:08 PM
bigal_700's Avatar
Default 6.5 timing injector pump
Ok this ia for a good buddy he has a amazing looking truck but no luck with engine. Truck when u start it knocks and when u rev it up it smokes bad has new injectors and injector pump. He talked to a diesel guy and he said it sounds like pump either advanced to much or detarted need help.
Old Nov 19, 2013 | 06:16 PM
racer55's Avatar
can't help if we don't know what year it is?
Old Nov 21, 2013 | 08:02 AM
bigal_700's Avatar
Its a 95 he said that the pump is advanced so how do i detarted it?
Old Nov 21, 2013 | 09:28 AM
racer55's Avatar
The electronic timing has to be set with a tech 1,tech II with OBD1 expansion pack or GMTD ScanTech pro version ONLY.
The only way to know what the timing is really,is to do a TDCO relearn with an above mentioned scan tool.
I don't know how anyone could determine advanced or retarded timing on their own?
Even using another scan tool that will display the stored TDCO value is in no way an accurate way to determine timing since it could very well be an old stored value that has nothing to do with the IP 's physical position.
To answer your question more directly,to retard the IP it needs to be loosened and rotated towards the passenger side,tightened and then the TDCO relearn needs to be done with the above mentiones scan tool.
Very small rotaion makes big changes eg: 1mm of movement translates to about 2 degrees of timing change.
Old Nov 22, 2013 | 04:28 PM
bigal_700's Avatar
Well i need to know how to fix with basic tools im not spending money for a fancy reader and i know my buddy isn't
Old Nov 22, 2013 | 05:58 PM
racer55's Avatar
Sorry to say that it can't be done with basic tools.
There is no way to set injection timing on a 94/95 electronic IP other than the scan tools mentioned above.
If you own a 94/95 6.5 you really should invest in the software/cable that goes with GMTD ScanTech pro version.
$160 for GMTD ScanTech
$60 for the cable
There is a way to make the cable for about $10 also but is a little crude.
Since the vendor is not a site sponsor I can't post the link but PM me if you want the info.
The ECM has to learn where the IP physically is situated at to control timing and to even report the timing to a scan tool.
The problem arises when the IP is moved or replaced-there will be a timing value in the computer that it thinks is correct and no matter where the IP's actual location is in relation to the crank the ECM won't know a change has been made unless it is commanded to relearn the new IP location-ONLY the above mentioned scan tools have the ability to force that relearn on a 94/95 6.5 electronic IP engine.
Old Nov 23, 2013 | 04:51 PM
man-o-war's Avatar
What about KOKO procedure to force relearn? I guess you still wouldn't know actual timing without tool
Old Nov 23, 2013 | 05:42 PM
racer55's Avatar
KOKO is only 96+ OBDII-yours is OBD1.
Old Nov 24, 2013 | 04:24 AM
sureshot's Avatar
Default new injectors
if your friend just changed injectors and hasn't drove the truck because of the knock, he needs to just drive it and the knock will go right away. i did my 95's and when i started it she knocked and smoked so i shut it off. only a good friends advice who is a diesel guru would i drive the truck with that noise it was making and with in a klm it went right away.
Old Apr 12, 2014 | 11:15 PM
bigal_700's Avatar
Well i don't think a computers will tell me wat i want its still mechanical driven and i see a mark on the engine block but not a mark on injector pump
Ill post a video tomorrow we will start it
