95 f250 power stroke
Old Nov 16, 2013 | 04:48 PM
70sgirl's Avatar
Default 95 f250 power stroke
Hi I'm new here as far as posting but have often visited this site for help in the past. My daughters 95 f250 7.3 power stroke has had a fuel leak for a while. It seems to have gotten progressively worse and now it will not start at all. My question is We took it in for an estaminet and was quoted $1000 is this about right? Also can a fuel leak make the truck not start eventually it had gas in it when she came home the night before? Just hoping the truck not starting is related to the fuel leak and not another problem.
Thx
Old Nov 16, 2013 | 05:08 PM
bcstroker744's Avatar
If it had gas in it that would probably be a major contribution to not starting
Sent from my SPH-D710 using Tapatalk
Old Nov 16, 2013 | 05:54 PM
70sgirl's Avatar
There was at least 1/2 tank or little more of fuel the night before. Is $1000 about right to repair? Thank you for your quick reply
Old Nov 16, 2013 | 06:00 PM
Did they happen to mention what they thought the problem was? If they just come out and say $1000 to fix it and nothing else is said about repair, id be taking my truck somewhere else... Kinda sounds like a shady place. The fuel leak shouldnt have anything to do with starting. My 97 had leaks in both front and back tanks for a while and was fine.
Old Nov 16, 2013 | 11:43 PM
Onis22's Avatar
Yes a fuel leak can be related to no start all depends on where the leak is need more info on problem to give better response
Old Nov 17, 2013 | 11:46 AM
70sgirl's Avatar
That was for replacing the fuel pump. They said they had to remove the turbo to get to replace the pump.
Thx
The leak is under the turbo
Thx
Old Nov 25, 2013 | 06:47 AM
Adrenaline junkie's Avatar
Sounds like your injector pump is leaking, common on 7.3 with high miles. Mine did ur too but was more to fix mine. Just make sure you are comfortable with your mechanic!
Old Nov 25, 2013 | 07:51 AM
joebob3093's Avatar
Moderator
Injector pump? The 95 7.3 does not have an injection pump but nice try.
As for the turbo having to be removed to pull the fuel pump, that is also false. It can be done with the turbo in place, I have done it myself. They are only telling you that so they can charge you more money.
Dec 10, 2014 08:10 AM
Oct 13, 2014 08:10 AM
