Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
HELP PLEASE.. I have a 2005 duramax 2500 6.6 diesel..
Old Nov 15, 2013 | 10:15 AM
cbrew2001's Avatar
Default HELP PLEASE.. I have a 2005 duramax 2500 6.6 diesel..
After my neighbor changed her fuel filter the truck ran for about 20 minutes then died... The plunger won't prime and fill the fuel filter now.. Can snyony tell me why the plunger isnt priming??? Thanks..
Old Nov 15, 2013 | 09:07 PM
Onis22's Avatar
Is the filter on correctly if there is a air leak prime can't build pressure did u change the o rings make sure old o rings r not stuck on house if all is good try removing filter fill with fuel and re install
Old Dec 21, 2013 | 04:58 PM
crazycooter's Avatar
start with the least obvious, and make sure it has fuel in the tank... that will definitely set a fuel filter warning.
wouldn't think of suggesting it if it hadn't happened to me before
Last edited by crazycooter; Dec 21, 2013 at 04:58 PM. Reason: Automerged Doublepost
Old Jan 12, 2014 | 12:46 PM
PolarXJ's Avatar
Filter housing could have bit the bullet if the filter o-rings are good. It is something fairly common and there is a filter housing rebuild kit available to fix the problem.
shane509
Potential Diesel Owners Forum
Sep 15, 2015 08:41 PM
david.burger
May 30, 2015 08:25 AM
DSM1988
Jan 25, 2015 07:23 PM
wolfnexus
Nov 4, 2014 10:04 PM
