2nd brand new power steering pump leaking...
Old Nov 10, 2013 | 05:53 PM
douger0500's Avatar
Default 2nd brand new power steering pump leaking...
I need some insight here. I've installed my second power steering pump and it's leaking out of one of the mounting holes on the back. It's starting to turn into a nightmare.
Any insight as to how the pumps break down and why the o-rings would fail?
I really would appreciate it.
,Doug
Old Nov 10, 2013 | 06:19 PM
Mayhem's Avatar
,Doug
Belt tensioner will do it if it has to much tension on it I smoked 2 in less than 6 months before replacing it on a gas burner this year
Old Nov 10, 2013 | 06:43 PM
douger0500's Avatar
No. Before even putting on the belt it's leaking out the mounting bolts. I just went to advanced. Picked up master seal kit. Any instructions on tearing em down out there?
Old Nov 10, 2013 | 06:56 PM
Mayhem's Avatar
Not sure are you using the o rings between back of pump and inside of resirvor ? should have them in the kit
Old Nov 10, 2013 | 08:02 PM
douger0500's Avatar
It's leaking out of one of the two mounting holes are. Where you put the bolt into the back of the pump to hold it stationary..
Old Nov 11, 2013 | 08:22 AM
jrsavoie's Avatar
What brand of pumps are you using? I try to stick with GM or AC Delco for a lot of parts
Old Nov 12, 2013 | 06:49 PM
tiremann9669's Avatar
b&hbiz
Sep 9, 2015 07:53 AM
ramrunner01
Jun 1, 2015 12:10 AM
bryan0702
Mar 18, 2015 05:03 PM
moneypitk5
Feb 12, 2015 11:01 AM
GCTownes
Oct 21, 2014 10:17 PM
