Ts chip
Old Nov 10, 2013 | 10:35 AM
farmboy6.9's Avatar
Default Ts chip
I just ordered a ts chip i have a stock 1997 with a 3in down pipe and a 4in straight its an auto tranny with banks trans control i was wondering if this chip will change the relyability of my truck my settings are stock 50hp 75hp 100hp high idle 140 hp my main concern is will my tranny hold up i dont plan to use the 140 setting at all just looking for some feed back trucks got 140000 miles on her
Old Nov 11, 2013 | 05:54 AM
bcstroker744's Avatar
I use a ts on my 97. Ive had no problems with it
Sent from my SPH-D710 using Tapatalk
140+ tune is a blast
Last edited by bcstroker744; Nov 11, 2013 at 05:54 AM. Reason: Automerged Doublepost
Old Nov 12, 2013 | 01:41 PM
96Power's Avatar
You will like it. I put one on my 96 and had no issues. It now has 389,000 miles and been on since 150,000.
Old Nov 12, 2013 | 05:45 PM
farmboy6.9's Avatar
Thanx for the input id like to ditch the trans control but when i unplug it my overdrive light flashes
Old Dec 23, 2013 | 08:23 AM
FL 95 7.3's Avatar
I purchased the TS Performance 7.3L Power Stroke Switchable Chip (6 Position) Item # TSP1180402 for my 1995 F250 7.3 turbo. I love it. I keep it at the 100HP setting. I read that the 140HP will need stage 2 injectors to get it. I did notice that I had oil leak from around the oil fill cap at 140HP. My plans are to rework the heads with after market head bolts that are longer and will hold up better to increased HP. As far as the power train holding up, I can not get and definitive answer on that. I did have the transmission rebuilt after the front main seal went out. It was reworked with a better torque converter and other parts since I haul a 5th wheel. Truck hauls like dream.
Old Dec 23, 2013 | 12:15 PM
joebob3093's Avatar
Moderator
If all your running is a chip you do not need any of that. You might look into a shift kit and a torque converter depending on what was put in it
Head bolts are bad, you want head studs and they are not needed till your pushing about 40psi of boost.
cumminspwr11
Mar 27, 2015 11:40 PM
Dieselhead1052
Nov 26, 2014 05:43 PM
Dieselhead1052
Nov 26, 2014 05:42 PM
Paintrain64
Nov 25, 2014 06:29 PM
corey352
10
Nov 20, 2014 08:04 AM
