strait axle swap on a 94 f 250
Old Nov 5, 2013 | 07:32 AM
johnnyringo's Avatar
Default strait axle swap on a 94 f 250
Dose anyone know what all needs to be done to do this
Old Nov 5, 2013 | 05:21 PM
Dortiz's Avatar
F350 donor truck will have everything you need
Old Nov 5, 2013 | 06:22 PM
joebob3093's Avatar
Moderator
D60, springs, track bar and mount
Old Nov 5, 2013 | 07:11 PM
Dortiz's Avatar
You may have to cut up some U-bolts a little, a little foggy but I'm pretty sure you will. Shouldn't take much longer than 2-3 hours to do the swap
Old Nov 5, 2013 | 08:01 PM
I have the hole f 350 do I need to swap the rear as well? Dose it all just go right over and bolt up the 350 is a 93 and mine is a 94 dose that make a diff?
Old Nov 5, 2013 | 08:11 PM
joebob3093's Avatar
Moderator
All you need to swap is the front. The rear is the same
Old Nov 5, 2013 | 08:12 PM
4x4manonbroke's Avatar
only if the gearing is different in front to rear ... having an entire donor is nice ....
if your going from a twin I beam to D-60 ... theres some work to do ... i reacall someone telling me that the K member is different .... not real sure , but worth looking into further
Old Nov 6, 2013 | 07:38 AM
What I'd the twin I beam the reason for the swap is the one thats in it I'm told will wear my tires crazy fast and although I did new wheel bearings ball joints and tie rod ends the tires still seam tipped in at the top
Old Nov 8, 2013 | 09:44 AM
I have it ....... and no wear ... its all in the set up of the alignment ..... im running Cooper AT/3's and pro comp 3000's .... it rides great and for the small amount of time that I actually wheel the truck , it does awesome .... unless ur gonna rock climb .... I would just suggest getting a real good set up on the front end .... I also did the add a leaf, and I'm running 315/75/16's and no rubbing ....... if u can, go to 4 wheel parts and have them align ur truck, its spendy .... think I shelled iut 175 or so ..... much worth it as the tires were 1100.00 ........ minor expence with alignment
Old Nov 8, 2013 | 05:50 PM
I have a 7 inch lift on mine with 315 75 16 as well I think my front end looks like it is two pieces
