Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
loss turbo pressure
Old Oct 29, 2013 | 07:15 PM
bgdog21's Avatar
Default loss turbo pressure
I recently loss my turbo pressure any ideas had no white smoke and some funny sounds please help
Old Nov 12, 2013 | 01:00 PM
96Power's Avatar
It could be a couple different things all of which are internal. Is it making any boost at low speeds, high speeds, or idle? If its not making any boost at all and you are not seeing any smoke it probably means you need an oil change. The dual turbo set up on these trucks is awesome and almost flawless. Most problems come from a lack of oil, whether it be from oil loss or fuel getting into the oil, or the DPF system. If its makeing boost at a higher speed then I would say the VGT plate needs to be replaced or cleaned. If its not making any boost I would try an oil change first. You could have broken the shaft that hold the turbine on also. You can tell this if youve lost that beautiful whistle that turbos give off.
caissiel
Sep 24, 2015 05:37 PM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
