1993 no voltage to TPS Sensor HELP
Old Oct 26, 2013 | 09:36 PM
chevyman0013's Avatar
Default 1993 no voltage to TPS Sensor HELP
I have a 1993 3500 Chevy with 6.5 td
I did injection pump and new tps when I replaced it I just set it like the other one was because I didn't have the tool. That was about 5 months ago. When I went to go set it today I couldn't get voltage at all to the pigtail! just a short shot of it when I would turn the key on. My dad did me the favor (sarcasm) of moving the sensor so now the truck only shifts at 2500 rpms and it will not go into over drive when you put ur foot in it. If I drive it regularly it shifts really hard. I parked it till I can find out what is up. any idea why I cant get a voltage reading? im thinking bad ground but I really don't know this older system....
All help is very much appreciated!
I really need this truck running tomorrow I just rained so hard in Arlington Tx
Old Oct 28, 2013 | 08:35 AM
racer55's Avatar
For your 93 the ECM is only a trans computer so grounding and power supply for it is where I would start looking.
Old Oct 30, 2013 | 12:57 AM
cviola2005's Avatar
If you are using a voltmeter, where are you grounding it? On the ground wire for the TPS? If so, try grounding it to the engine somewhere.
Are you sure that you are checking the correct wire for voltage "to" the TPS?
IIRC, when I had to set my TPS, seems like the idle position should have been around 0.42 volts on the signal wire. The signal voltage raised with the throttle to around 5 volts.
Hopefully this helps.
john grossman
10
Jan 12, 2019 08:58 PM
Seann12
Jun 17, 2015 10:40 AM
robbyS
Apr 16, 2015 02:22 PM
Genghiscarl
Oct 27, 2014 10:19 AM
