leaking diesel
I have 1999 F250 that has a leak underneath. After the truck engine runs for a couple minutes the leak starts. I crawled under the truck and found a piece of tubing with the diesel dripping our of the end. It looks like there may have been a tube attached to that tubing, but I can't find where. Can anyone help me?
Water separator off the fuel bowl... The new ULSD eats the O-rings up... You can buy a new separator from ford or just the o-rings online if you want to rebuild it.
Sent from my iPhone using Tapatalk 2
The drain bowl valve may need replaced. I had a similar leak but mine was when I shut down and it sat for a little while. Once I changed the drain valve ($56 from the dealer) no more leak. At least not that I have seen.
like others have said already, it is the water separator valve on the fuel filter bowl. The part is about $40 if you go to an autovalue store, or a little more if you are a die hard Ford guy and buy everything from the dealership. Fairly simple part to swap out, just a touch messy with all the diesel that will leak out when doing it. LOL
mine was leaking real bad, got new water separator gaskets from RiffRaffDiesel fixed everything dry as a bone now.....at least where it needs to be dry.
Fluorosilicone Drain Valve Orings Set - Riffraff Diesel Performance
Complete Fuel Bowl Seal Kit 99-03 - Riffraff Diesel Performance
he also has a really good write up on how to do it.
Jet A Fuel
Aug 3, 2015 10:45 AM
May 28, 2015 11:45 PM
Mar 18, 2015 07:30 PM
