No Start issue 04 6.0 L
Old Oct 19, 2013 | 07:03 PM
bnbracin12's Avatar
Default No Start issue 04 6.0 L
I have a 04 F-250 6.0L . Stock completely, other than k&N filter box.. had a hot no start issue. Hooked up scanner, made no oil psi on icp , 30-80 psi max then would go to 0 right away soon after long cranks.
Had done:
Supply tubes and plugs update
New discharge tube on HPP
New HPP
Makes 107 psi max after long cranks no more... any ideas? I pressurized system through ICP sensor with 130 psi.. no leaks and did not leak down.. I'm stumped...relief valve on LPP?
CJ Morin
19
Nov 20, 2018 07:30 PM
Cavnar
Sep 9, 2015 07:18 PM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
thumperf350
Jan 8, 2015 12:55 AM
